Gasket Kits - Where From
Old Apr 12, 2020 | 06:36 PM
adduk's Avatar
adduk
Default Gasket Kits - Where From
Just ordering the gasket kits to build a Silvertop zetec turbo. Where are people getting their gasket kits from? Is Burton Power kits worth it?
Also what about head gaskets, what you guys recommend and where from for the silvertop.
Old Apr 13, 2020 | 10:22 AM
MK5 ESCORT's Avatar
MK5 ESCORT
I recommend victor reinz items not had a problem on any of my builds
Head Gasket all depends what thickness your going for.
Old Apr 13, 2020 | 10:41 AM
adduk's Avatar
adduk
It’s a standard bore size 84.8mm, head had 1 skim and Wossner pistons CR of 8:0.1. Looking for advise on the best size based on the above.
will look into the gaskets cheers!
Old Apr 13, 2020 | 04:04 PM
nickharding's Avatar
nickharding
Fully recommend Victor Reinz also. Best out there,
Old Apr 13, 2020 | 05:13 PM
gcfcos's Avatar
gcfcos
Same here, put a head gasket in my cossie 10 years ago and still going strong with 26psi of boost.
Old Apr 13, 2020 | 08:03 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
victor reinz are great. use 61-34340-00 headgasket as it's slightly thicker than the standard one. you can buy a head gasket set for the rest of the bits.
Old Apr 14, 2020 | 05:57 PM
adduk's Avatar
adduk
Cheers for the part number. I will look at getting one sorted.
When you say its slightly thicker, isn't the Silver top standard gasket 1.8mm and the blacktop 0.8mm? The one you have suggested is 1.3mm? I don't think it will make much difference.
Old Apr 14, 2020 | 06:39 PM
MK5 ESCORT's Avatar
MK5 ESCORT
Standard ST170 is finnis 1071744 Which is victor reinz part no. 61-34340-00
2.0 Blacktop And FOCUS RS MK1 are 0.6mm i believe part no. 61-34440-00
1.8mm for skimmed heads but they are hard to get, better of going for a cometic or similar to get thicker, burton power have around 1.8mm for turbo usage.
Hope this helps
Old Apr 14, 2020 | 10:22 PM
Turbo Zetec
Engine Machinist
the silvertop gasket is composite and not designed for turbo engines (in the old cvh engines the fire rings were much thicker on the turbo head gasket than the regular ones). MLS gaskets, being all metal, don't have a problem with fire rings generally so are good to use on all kinds of engines - turbo, supercharged, with nitrous - it doesn't really matter.
Old Apr 15, 2020 | 08:17 AM
adduk's Avatar
adduk
Spot on cheers pal!
Old Apr 15, 2020 | 08:18 AM
adduk's Avatar
adduk
Hope this helps
Massive help Cheers
Fewkesy
Jan 16, 2009 09:41 PM
mitchrst
Feb 10, 2007 10:57 AM
righthooker
Apr 9, 2006 02:24 PM
makaveli662
Jul 7, 2004 05:24 PM
