esc cos small hole in bottom of water pump water leaking?
Old Apr 14, 2005 | 02:55 PM
rs cos's Avatar
rs cos
Default esc cos small hole in bottom of water pump water leaking?
there is a small hole in the top and bottom ot the water pump about 4mm wide i took pump off to clean and now its back on there is water coming out that small hole at bottom! help please
Old Apr 14, 2005 | 03:31 PM
dangerous - reyland's Avatar
dangerous - reyland
Its Fcuked
Had the same problem
Buy another but New ones aint cheap -abt Ł 130? from memory
Remember 2wd not the same as 4wd
Old Apr 14, 2005 | 03:46 PM
rs cos's Avatar
rs cos
tell me it's not fucked please, it was fine when i took it off
Old Apr 14, 2005 | 04:37 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
yep, its no good
Old Apr 14, 2005 | 04:43 PM
Chris Honeywell's Avatar
Chris Honeywell
Tis shagged m8
Old Apr 14, 2005 | 04:57 PM
markk's Avatar
markk
you took the water pump off to clean it ?? well how stoopid was that - you wont do that again will ya
Old Apr 14, 2005 | 05:03 PM
rs cos's Avatar
rs cos
the car was lying up for three years when i bought it a few months ago so you can imagine what i have had to do. the water pump is not all that came off!
Old Apr 14, 2005 | 05:29 PM
markk's Avatar
markk
ok my apologies , i thought for a min that its was a bufty job !
im afraid it is time to fit new tho these are there as early warning tell tales for the water pump wear , tis the only fix
mark
Old Apr 14, 2005 | 05:31 PM
phil4x4saph's Avatar
phil4x4saph
Trust us!! ITS FOOKED!!!!!!!
Old Apr 14, 2005 | 05:40 PM
rs cos's Avatar
rs cos
ok ok i agree with ya's ive new one ordered! thanks for that
3i Jim
Nov 20, 2015 05:12 AM
3drRich
Sep 13, 2015 07:32 PM
cameron2
Aug 25, 2015 07:18 AM
MARKYMARKONE
Aug 20, 2015 12:55 PM
john_3.0s
Aug 15, 2015 07:44 AM
