Cosworth turbo part numbers
What Sapphire have you got? 2wd or 4x4 and are you after a standard turbo? There are loads of places where you should be able to get a standard turbo and they will know which one you need without specific part numbers.You did'nt think you could still get one from a Ford dealer did you?
Doing a 8v dohc turbo conversion and just looking part numbers to know exactly what turbo I'm looking for as searching for t3s and t34s seems to bring an array of different turbos. And yes just standard turbo
cheers
cheers
I would have thought that because it is not specific for a Cosworth YB engine any of the T3 or T34 turbo's will be fine. The T34 will give more performance than a T3 but it depends on what other modifications you are doing on the engine.
boXXer
11
Apr 3, 2007 10:16 PM
