Connect 2011 1.8cc
Old Mar 12, 2020 | 11:24 PM
Kweildi's Avatar
Kweildi
Default Connect 2011 1.8cc
Stopped does not start
cranks over but does not fire.
Changed fuel filter and bled through so fuel at all 4 injectors
Gave it a puff in air inlet never did anything
Crank it over and dash goes blank then starter cuts out so it does not overheat
anyone got any ideas please
Old Mar 13, 2020 | 07:45 AM
oldford's Avatar
oldford
If the dash goes blank, then it looks like an empty battery to me.
Old Mar 13, 2020 | 10:56 AM
Kweildi's Avatar
Kweildi
Brand new battery put on
Old Mar 13, 2020 | 08:08 PM
GVK.'s Avatar
GVK.
Timing belt ok?
May have 2 belts the lower being a 'wet belt' which are known to fail.
Old Mar 14, 2020 | 10:46 AM
big_wasa's Avatar
big_wasa
If the dash goes blank when cranking ie high load then it's an electrical fault like a loose connection ot a bad earth.
Old Apr 6, 2020 | 11:46 PM
sneddspeed's Avatar
sneddspeed
Un plug no1 or no4 inj lead ' see if will start on 3 injectors
Kweildi
Mar 12, 2020 08:38 PM
nextural
Jun 15, 2018 06:46 PM
DJ_Steve
Nov 6, 2016 04:11 PM
40
Mar 21, 2013 06:10 PM
johnpaul6
May 15, 2010 10:58 PM
