Saff cossie side skirt fitting kits
Old Feb 5, 2020 | 02:54 PM
james kiely's Avatar
james kiely
Default Saff cossie side skirt fitting kits
Any one know of a quality side skirt fitting kit as most of mine are broke
Also looking for rivets for along the tops of the skirts
Old Feb 5, 2020 | 03:34 PM
BIG LEE's Avatar
BIG LEE
there are kits on ebay but tbh i can tell you now there sometimes brake when fitting my car is mint the sill lips are not scabby or swelled but i still had bother with clips smashn as u push them on i found the kits are on if modified them so gap is bigger then the norm to stop the stress as you fit them. i think the kit i got was from spain £50
Old Feb 5, 2020 | 03:40 PM
scoooby slayer's Avatar
scoooby slayer
https://www.google.com/url?sa=t&sour...=1580920764372
Old Feb 5, 2020 | 04:17 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I used a metal kit off eBay fitted fine way better than the plastic rubbish
Old Feb 5, 2020 | 06:16 PM
james kiely
Cheers Lee, good info buddy
Look like the kit below?
Originally Posted by scoooby slayer
Cheers karl
I will look into them also Andy thanks
Old Feb 5, 2020 | 06:22 PM
jason_nike's Avatar
jason_nike
Thats the same kit I got.
Seller was reliable and quality seemed good.
https://www.ebay.co.uk/itm/Sierra-Sa...0AAMXQaBtQ9ycj
Old Feb 5, 2020 | 07:21 PM
qed296's Avatar
qed296
I went for the ones from msd.....finished in satin black...not cheap but no braking problems.
https://shop.motorsport-developments...-kit-860-p.asp
Old Feb 9, 2020 | 08:11 AM
The Youth.'s Avatar
The Youth.
My mate has remade these clips in plastic and redeisgned them to better than original ford ones to reduce the chance iof them snapping
my clips were used as a templates, they are available in rivit on as original or bolt on
dearch for cllips n bits on facebook hes on here aswell robrs2
Steve
Old Feb 9, 2020 | 09:45 AM
Adam-M's Avatar
Adam-M
I bought the 3D printed ones can’t fault them but need to heat them to soften them or they can be brittle
james kiely
Feb 5, 2020 02:34 PM
heepsy1
Oct 12, 2006 09:27 AM
xr2fatturbo
Jul 17, 2005 02:32 PM
r5jame5
May 8, 2005 04:21 PM
