YB head thickness question :: Need Help
Old Feb 1, 2020 | 06:46 AM
josenovo's Avatar
josenovo
Default YB head thickness question :: Need Help
Hi All,
I would like to ask if someone can help me how to get the correct head gasket thickness with the below engine specs:
  • Head Measure: 137.4
  • Bore: 91.33
  • Crankshaft bearings : 0.25
  • Pistons rings: 0.25
If someone can help me i really appreciate it.
Thanks.
Old Feb 2, 2020 | 11:22 PM
20/20 vision's Avatar
20/20 vision
From: it's not where you are, it's where you've been and where you hope to be
if you mean to achieve a particular compression ratio then only the head thickness in the above list is significant (the overbore will make a minor difference).
you also need to know the volume above the piston at TDC and the combustion chamber volume in the head, which, if its a 2wd head at that thickness, will likely be around 45cc.
1) determine the desired compression ratio and work out the required CC's to achive this (= REQVOL)
2) add together the volume above the piston in CC's and the head's combustion chamber volume in CC's to get value Z.
3) subtract Z from REQVOL and the remainder is the volume of CC's required in the gasket.
4) each miilimetre of gasket thickness will add another 6.5CC
carterhall14@hotmail.com
May 15, 2016 08:30 PM
MalteseFalcon
Aug 6, 2010 03:22 PM
lamb chops
33
Jul 3, 2008 04:44 PM
Daveysaff
Nov 24, 2007 03:43 PM
PGT
May 5, 2007 05:24 PM
