anyone heard of sierra cossie clocks, in an s1???
Old Apr 14, 2005 | 12:20 PM
flax's Avatar
flax
Default anyone heard of sierra cossie clocks, in an s1???
just started doing the efi conversion on my s1, using cossie sensors, injectors etc. just thought if my rev guage will work on an efi system?
so i was thinking of maybe fitting cossie clocks. any ideas lads?
Old Apr 14, 2005 | 06:56 PM
Dan's Avatar
Dan
Sure its been done before mate, think there is/was a couple of RST's knocking about with the 170mph clocks in them!
Someone will be able to advise you better on here i'm sure mate as I don't personally have an RST HTH
Old Apr 14, 2005 | 09:58 PM
flax's Avatar
flax
cheers dude. thought i`ve seen it somewhere myself but been through all my mags and couldn`t see one.
anyone else know much about this??
Old Apr 15, 2005 | 08:14 AM
JesseT's Avatar
JesseT
The S1 clocks will work, no problem. If you're going wasted spark, then there's a couple of ways to go around it.
Old Apr 15, 2005 | 08:57 AM
flax's Avatar
flax
yeah more than likely. was thinkin bout usin crank sensor to trigger ign on wasted spark system and the cam/phase sensor for fueling. seems like the easiest way to do it to me. instead of seperate coils etc.
so how do i get around it and do they need much modifyind to fit?
cheers.
Old Apr 15, 2005 | 10:55 AM
JesseT's Avatar
JesseT
'i'm not a specialist in Weber Marelli managements (I favor MegaSquirt if you havent noticed ), and don't know how to convert one to wasted spark. But, if you manage to do so, then you can drive the rev-counter from the coils using three diodes like this:
In ford's efi managements one can just take pin 11 form the EDIS-4 to drive the rev-counter. Most people seem to change the entire instrument panel for no reason.
Old Apr 15, 2005 | 12:36 PM
flax's Avatar
flax
i was looking at using the emerald m3d system on it .
Rsmat
63
Sep 25, 2015 12:11 PM
Adam Graham
Sep 6, 2015 06:04 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
