Fuse box issues
Old Dec 7, 2019 | 10:35 AM
Joshmk1's Avatar
Joshmk1
Default Fuse box issues
Not long had my s2 bought it with heater blowers not working inside car so thought I’d dive in have a look.
also noticed my indicators occasionally stop working! Pulled fuse box cover off and found this!
Got a tad hot there I would say! Now I know there is ment to be another yellow relay There can abit tell me what it’s for ?
Old Dec 7, 2019 | 03:02 PM
martysmartie's Avatar
martysmartie
I don't know the RST intimately to know what it is, but there should be a legend on the underside of the cover, or failing that the handbook would tell you.
Also you can see the fuse is melted as well, this may be the supply that is switched via the relay, clearly someone has not bothered to replace the fuse. This needs doing immediately!
There is a good chance this is the heater motor, although relays are not usually used.
Does the cooling fan work?
Regardless, it will have to be rewired externally now.
The reason this happens is due to a heavy consumer, that melts the fuse box when powered on for a while.
Martin
gcfcos
12
Aug 8, 2014 08:29 AM
HOTTIGGER
Feb 6, 2011 09:40 PM
Modder_J
Aug 26, 2006 11:04 AM
Shandy-Ade
Jan 10, 2006 05:17 PM
