series 2 rs Cold start problems
Old Nov 25, 2019 | 07:50 PM
Buster42's Avatar
Buster42
Default series 2 rs Cold start problems
Hi guys the car has been garaged for a long time and won't start. At first I thought fuel pressure but that's fine. Getting a spark but plugs are dry so took the plug off the cold start and I'm only getting 9.5 volts and know I need 12 volts any advice on what to check next is appreciated
Old Nov 26, 2019 | 02:13 AM
t230's Avatar
t230
Did you try starting with out the cold start plugged in - iirc its the beige/yellow plug back on inlet?
Old Nov 26, 2019 | 07:19 AM
paulee's Avatar
paulee
Hi , i have a similar problem with my xr3 but mines only fires up on the csv , no compression no to sure where to go as well.
Is there any noises or power when starting it? u checked or replaced the bat?
Have u made sure the injectors are working , take them out but keep them connected to fuel lines put them in bottles and turn the car over they should spray out nice - or you could carefully undo the clips on the fuel distributor ( metering head ) , take the air filter out , turn the car over and slowly lift the plunger under it at the same time might need a mate to help.
Old Nov 26, 2019 | 06:22 PM
Buster42's Avatar
Buster42
Tried unplugging and still the same
Old Nov 26, 2019 | 06:26 PM
Buster42's Avatar
Buster42
the battery is new I've got fuel pressure and when I turn the car over and press the flap under the airfilter/ metering head it still don't start and get a strong smell of petrol, I tried it today with easy start spray in the intake and again nothing???
Old Nov 27, 2019 | 06:38 AM
t230's Avatar
t230
Usual checks then - fresh fuel? injectors pulsing?
Old Nov 27, 2019 | 09:31 AM
Buster42's Avatar
Buster42
Put 10 litres in but not getting any petrol to the injectors until I press the flap down on the metering head. Spoke to a guy in the local garage and he said it won't start until I get 12volts to the cold start
Old Nov 27, 2019 | 01:03 PM
t230's Avatar
t230
is 9.5 volts reading from battery? yes u need 12 minimum - start with a new battery sorry i didnt read the post properly .:0
Old Nov 27, 2019 | 04:31 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
the 12 is fed from blue black wire on ignition > there will be an intersection where wires are added at the point it turns to black yellow,..
it also goes to pin 24 jetronic black box ,
from that intersection it also feeds the thermo time switch, guess thats techincal name for a sensor ,
so check 12v is flowing through blue black, at ignition , on stage 2
Old Nov 30, 2019 | 07:01 AM
paulee's Avatar
paulee
Did you get your 12 volts to the csv?
Old Nov 30, 2019 | 07:13 AM
Buster42's Avatar
Buster42
No mate not yet I've not had time I've got 7.9 to the black box on the metering head and 7.5 to cold start , I will have another go tomorrow afternoon
Old Nov 30, 2019 | 07:29 AM
paulee's Avatar
paulee
Mate im no pro but im sure it should start up without the csv. Did you take that off seperate as well and spray the injector into a bottle?
Old Nov 30, 2019 | 07:37 AM
Buster42's Avatar
Buster42
No mate that's my next job, I seen somewhere that the cold start voltage can be anywhere between 9-12 volts? I did notice some petrol sat in the throttle body so think it might be working.
CHRISP
Aug 5, 2014 09:08 PM
DangerousBryan
Sep 10, 2012 11:43 AM
Andie
16
Sep 17, 2009 06:27 AM
Lee_R21Turbo
32
May 23, 2008 09:01 PM
Phil
58
May 16, 2005 07:30 PM
