Wills ring 200 block
Got a 200 block from my 4wd which as got wills ring cut into the top these rings are gas filled been looking for years to find some which is the right diameter but I couldn't find any so my question is best place to get the block surface skimed to get rid of the Grove it's a genuine 200 block never been cooked I have ad it for a long time with the caps just taking up space all the bores are greased up don't kno if this is worded right
How deep is the groove ricky? Without seeing it, I'd presume that a lot of material would need removing?
https://www.tss.trelleborg.com/en/pr.../wills-rings-o these kind of things?
PassionFords Creator
If So - Burtons or GGR sell them.
ok will give ggr a shout and i think you right need to find out as well if you change the gascket do yo always have to change the rings cause dont think the kit is excattly cheep
SS1
Jun 8, 2007 11:34 PM
frosty
32
Jan 30, 2007 08:15 PM
TheBishMan
Jul 19, 2006 03:55 PM
MadMac
23
Apr 27, 2005 08:08 AM
