Brake pipe
Old Nov 19, 2019 | 03:17 PM
martysmartie's Avatar
martysmartie
Default Brake pipe
Hi,
After many years of going through MOT's without an issue, it has failed this year due to a kink in my rear offside brake line (wishbone to flexi on a Cosworth) which has always been there.
Ideally I wanted to get another without having to flare, as I neither have the tooling for this, nor the fittings.
Does anyone know who does these, as I have tried searching online to no avail.
Thanks,
Martin
Old Nov 20, 2019 | 05:44 PM
stevieturbo's Avatar
stevieturbo
C**t
Get the Flaremaster 2 from Sykes....and just DIY.
Although surely any garage could make you up a pipe if you take the old one to them ? Kunifer preferably.
Old Nov 20, 2019 | 07:13 PM
martysmartie
Thanks, Stevie.
That is what I am going to do, my garage says they have the fittings as well.
Martin
Old Nov 20, 2019 | 07:19 PM
stevieturbo
C**t
Any motor factors, ebay, whatever will have the fittings.
Or at a search, I think some stainless fittings are available.
Flaremaster 2 is a great tool though. There are cheaper options out there, but other than a tool that goes into a vice, it's probably the best and most practical and can be bought for sensible money on ebay etc.
Old Nov 20, 2019 | 07:27 PM
studabear's Avatar
studabear
These are the absolute nuts, they will flare steel pipe on car too.
https://www.ebay.co.uk/itm/Brake-Pip...204da1c90d52ae
But as Stevie says a garage should make you up a pipe if you take yours for them to copy.
Old Dec 6, 2019 | 07:23 PM
burnzy's Avatar
burnzy
burnzy
I’ve flared steel with the cheap eBay jobbies.
grass racer
13
Aug 27, 2013 07:54 PM
raycov
Jan 7, 2012 06:37 PM
pnwrs2000
Sep 14, 2009 03:27 PM
AJ-RST1
Mar 14, 2009 01:44 PM
Moose 130
Jan 5, 2005 12:05 AM
