Cosworth fuel pressure regulator
Old Nov 5, 2019 | 08:26 AM
timsrs's Avatar
timsrs
Default Cosworth fuel pressure regulator
Im running a L8 ECU is it possible to use an aftermarket fuel pressure regulator
the one I’m looking at is the sytec as below
will it work fine through the boost range or is it best to stick to original
thanks
Old Nov 5, 2019 | 09:00 AM
christos's Avatar
christos
10 Year Member
Original fpr Weber is far much better than sytec. Why do you want to replace it?
Regards
Old Nov 5, 2019 | 09:54 AM
timsrs's Avatar
timsrs
Regards
I’ve got all AN fittings throughout the car
The original fuel rail and regulator don’t allow them to be fitted
Old Nov 5, 2019 | 12:10 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
I've been running that sytec regulator on mine with L8 for years now without any issues. I think i got it from MSD.
Having said that It is definitely a bit of a low-mid range budget option and doing it again i would probably spec the best i could afford as the fuel delivery system is so critical.
The choice is yours...
Old Nov 5, 2019 | 06:06 PM
turbotrev's Avatar
turbotrev
Regards
Why is the original Weber one so much better?
especially if it is 30 years old?
Cheers Paul
Old Nov 10, 2019 | 10:24 AM
shark91's Avatar
shark91
Uses the one sold by anembo machined in the mass with an escort capsule. There are leaks with these regulators adjustable especially if you use a manometer
damien roe
Aug 19, 2017 06:46 PM
BillsCossie
Oct 22, 2010 06:07 PM
sonmic
Jul 12, 2010 11:59 AM
JanDK
Mar 3, 2008 01:12 PM
jabcos
Jan 12, 2008 07:29 AM
