Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
St225 info
Old Oct 12, 2019 | 08:56 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Default St225 info
Anyone know anything about the front headlight washers? If you push the washwipe button they pop out and back in very quickly but no water. If you power the pump with a power probe they spray water. It’s as if the water is running back so the time they work on the button doesn’t give the pump enough time to get the water up there. It’s a new pump. Is there a one way valve in the system? Is there a relay that controls how long they spray for?
Also dose anyone have a picture of how the rear headlight auto adjuster sensor and mount sit? I can’t work out where it goes or how on the beam.
jacques
Sep 26, 2012 01:21 PM
mattman1234
Apr 16, 2011 08:17 AM
////ANTHONY
Feb 3, 2007 05:32 PM
