Project wont crank help Ford scorpio 2.3 16v
Old Sep 27, 2019 | 03:13 PM
Mantas's Avatar
Mantas
Default Project wont crank help Ford scorpio 2.3 16v
Hello, i have Ford scorpio 1996 2.3 16v ghia i drive it daily ant then i put the engine and all the wiring to Ford sierra mk2 not cutting the wiring at all and have the issue no crank no start at all, starter motor ir working fuses ir good, everything is in the plays, oddometer is working, but wont use the airbag module, imobilaizer is correct and in the plays, and fuel pump not working then turn the ignition on, can anyone have idea what i need to do ?
To crank it ? I was disconented imobilaizer and connected again, that Ford needs to reprograming imobilaizer or not ?
Old Sep 29, 2019 | 08:20 AM
Mantas's Avatar
Mantas
Nobady gives a sh*t on this page, very nice helping guys 👍
Old Sep 29, 2019 | 08:44 AM
RichieST's Avatar
RichieST
Nobody gives a shit, or maybe nobody knows? To be fair your first post was fairly difficult to understand and you were fairly shy on details. Dont let the door hit you on the way out.
carlos1395
Ford Focus Range
Jul 23, 2012 09:48 PM
-beefy-
Sep 26, 2010 07:44 PM
cossie*mad!
Jun 19, 2009 06:18 PM
bigmatt-s2rst
Jan 25, 2007 01:14 PM
whitneyd
Sep 27, 2005 07:36 AM
