Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
focus mark 1 1 and 4 no spark
Old Sep 14, 2019 | 11:05 AM
alanc2k's Avatar
alanc2k
Default focus mark 1 1 and 4 no spark
hi all
need some help here where to go next
I suddenly lost sparks to cylinders 1 and 4
changed the coil pack but this made no difference
I have found there are only 2 coils in the pack and that 1 and 4 are fired together so I am guessing the signal that controls 1 and 4 is missing
where should I look next ?
I thought about the cam position sensor although I assume that as 2 and 3 run fine the sensor must be ok or am I wrong ?
many thanks
alan
Old Sep 14, 2019 | 05:26 PM
studabear's Avatar
studabear
Check wiring between coil and the edu. If that's fine expect a ecu fault.
Old Sep 14, 2019 | 05:51 PM
big_wasa's Avatar
big_wasa
What engine ?
I would start with continuity between the coil and ecu.
Old Sep 15, 2019 | 05:59 AM
alanc2k's Avatar
alanc2k
thanks studabear and big wasa
it is looking like an ecu fault
can I just swap it for one from a breakers yard ? will I need at least the key as well?
thanks
alan
Old Sep 15, 2019 | 12:18 PM
big_wasa's Avatar
big_wasa
Yes, you will need the chip from the key as well.. You can stick the new chip into the old key to save messing with the locks.
Not sure on the mems control unit. But if you where at the scrap yard I would get the full set to be sure.
I would still check the wiring first.
packman
Jul 6, 2014 06:33 PM
chip RS
41
Nov 21, 2012 01:28 PM
bigluke200
Oct 10, 2011 01:54 PM
rst deany
Oct 2, 2008 10:37 PM
RigPig
Feb 20, 2005 10:09 AM
