Best place for a new T36.63
Old Sep 9, 2019 | 01:11 PM
CHRISP's Avatar
CHRISP
Default Best place for a new T36.63
Any recommendations??
I’m looking to change from a Garrett t34.55 to a t36.63, I’ve been in conversation with turbo technics for a few weeks but they don’t appear to coming back to me for some reason(??)
Old Sep 9, 2019 | 06:07 PM
james kiely's Avatar
james kiely
I have a maram shafted t34.63 Chris 1000 pounds
Old Sep 16, 2019 | 09:29 PM
mcbernie's Avatar
mcbernie
Tony. Turbosystems should sort you out
Old Sep 16, 2019 | 10:24 PM
markk's Avatar
markk
In the bin. Buy a modern turbo.
Old Sep 18, 2019 | 07:07 PM
dan le moignan's Avatar
dan le moignan
Chris why would you want to change from the .55?
I had a .55 on my one on msd 380 kit and it was good.
Just changed to an EFR now
Old Sep 18, 2019 | 07:47 PM
dan le moignan
These guys are great if you do still need one and good knowledge of ford Cosworth stuff
https://www.turboperformanceltd.com/
they are on Facebook also and reply quickly
Old Sep 21, 2019 | 01:48 PM
RSMK4TURBO's Avatar
RSMK4TURBO
I have the MSD 380 setup on a T35.55, how does the EFR compare?
Old Sep 21, 2019 | 04:15 PM
Mark Shead's Avatar
Mark Shead
It doesn’t compare it is that different a big step forward
Mark
Old Sep 21, 2019 | 07:45 PM
CHRISP's Avatar
CHRISP
Just going for a bit of a change dan, the t36.63 turned up today, it’s going on with a new 500 cooler, 72’s, -34 actuator, als and l/c, wasted spark, braided engine loom and a map
Old Sep 21, 2019 | 09:32 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Mark
Oh ok, whats needed other than the turbo,manifold? can i still keep L6 management?
Old Sep 21, 2019 | 09:55 PM
dan le moignan
Ah ok Chris, will be interesting to see what you think of the bigger housing as thought the .55 was the best all rounder!
Ive not picked the car up yet and still needs mapping, was just getting the turbo and a few bits changed.
unfortunately turned out my head gasket was leaking so put a WRC one on on standard reinz bolts so fingers crossed it should take some ok boost now.
Not sure what power or boost it will run as engine is standard other than 500 type intercooler.
I would like around 450hp not sure if that’s a realistic target on the 7064 twinscroll
Old Sep 22, 2019 | 05:02 PM
turbotrev's Avatar
turbotrev
If you want to yes
Cheers Paul
snoopaloopa
Dec 12, 2010 07:42 PM
rst in breaking
Jul 5, 2009 11:00 PM
cfoster
37
Sep 14, 2004 09:51 AM
