I have a 90 spec rs turbo , i have decided to ditch the abs
so I have 4 fresh pipes going from the wheels straight to the servo area
I want to replace the master cylinder with a unit that has 4 outlets
so my questions are ,,, what cylinder can I use and do I need some kinda valves inline for the rear brakes
understood . well most logical is non abs set up with the rear line valves from same non abs car xr3i mk4
4 ports on the m,c the most forward on the logo side is bigger, same as the oversize from abs cars too
Yeah that will do ya, it is fitted below the wiper mount and above steering outlet on bulkhead, on the side abit,
theres 2 nuts already sunken into shell
