Escort RS1600i This forum is for all things about the Escort RS1600i
Rs1600i no spark help please
Old Aug 30, 2019 | 06:44 PM
garypara's Avatar
garypara
Default Rs1600i no spark help please
Hi im restoring a rs1600i & for sometime i've have no spark, i did get it running briefly, initially it would rev up but misfiring, that turned out to be over fuelling, sorted that out then it would idle nicely but not rev up, shortly after that it wouldn't start at all, no spark, i bought a new flywheel sensor which has been tested twice, both coils tested twice, ecu overhauled & then replaced, wiring checked as per the wiring diagram but still no spark, any ideas? does anyone know of a mobile auto electrician with an oscilloscope in the cambridgeshire area?, initially you could hear the fuel pump prime prior to starting but since i've had my ecu overhauled & then replaced that doesn't happen, any help would be greatly appreciated
Old Sep 27, 2025 | 04:16 PM
CN Fox's Avatar
CN Fox
Hi. Did you ever get this resolved as I have the same issue and can’t fix!
garypara
Escort RS1600i
Jun 25, 2019 08:01 PM
16vzetec
Aug 17, 2012 08:44 PM
w4yne
Oct 10, 2009 09:11 PM
w4yne
Oct 3, 2009 05:21 PM
mudgey
Jan 15, 2008 07:25 PM
