Series 2 backfire on boost and no go
Hi my rs turbo has an issue with boost. It boosts lovely on 1st 2nd and 3rd but when you get to 60-70mph in 4th or 5th it struggles like its hitting a wall then suddenly it will drop revs to 0 then do a massive back fire then engine with go back to normal and go back to the revs it should be. Just wont boost properly. Did it all before head gasket was done and also its setup. What else can it be now? Cheers in advance
Sounds like it to me, 12 psi on stock ecu is too high in my opinion, that said it's about 20 yrs ago since I had my RSTs
Before I had mine chipped with a Bayjoo chip I had an incar bleed valve which was a balancing act between having loads of boost then the sudden boost cut, which was interesting while overtaking...lol
Before having the bleed valve, Mine used to spike about 15 psi but then drop down below 10 psi so not to hit boost cut.
markax
Mar 3, 2009 11:42 PM
