Quaife peg or vernier cam pulleys
Jul 30, 2019 | 12:26 PM
Which is the better ??
Are the peg ones not as a fine adjustment
can anyone tell me the pro’s and cons to either
cheers
Jul 30, 2019 | 05:14 PM
There’s not as much adjustment on the Quaife peg type but they do look good, I have a set if your looking for some mate.
Jul 30, 2019 | 07:46 PM
Ok
im hoing to get in touch with my mapper
he’s settler the car up for me
cheers
Jul 31, 2019 | 01:58 PM
You can get perfect adjustment on the Quaife ones there just a tad fiddly to setup I would use them over the 3 or 4 bolt adjustable pulley
Jul 31, 2019 | 07:03 PM
I prefer them to Jay but didn’t want to sound biased as I’m selling a set lol.
Jul 31, 2019 | 07:12 PM
I have used all types and express no preference but technically quafie better as should never come loose.
Mark
Jul 31, 2019 | 07:27 PM
My mate had a lucky escape 2 weeks ago when the bolts in his exhaust vernier came loose. He came back in from a blast and heard a jingly sound. Opened the bonnet for a look and a couple of the bolts were falling out lol
Jul 31, 2019 | 10:23 PM
I've got the quaife steel peg pulley's. Fit and forget
Aug 16, 2019 | 06:21 PM
I wouldn't use anything other than quaife as i had a set of the other type move causing all 16 valves to fuck up
Aug 16, 2019 | 09:29 PM
Aug 17, 2019 | 05:54 PM
Quaffed ones it it then
thanks all
Aug 19, 2019 | 10:00 PM
From: it's not where you are, it's where you've been and where you hope to be
quiafe are steel and last whereas others are typically aluminium and wear out quickly. as said above however, quiafe are fiddly to adjust untill you work out a tecnique or make a special tool for the job !
mcbernie
Sep 22, 2012 05:31 PM
Fezman1
Jan 18, 2011 06:10 PM
jonnyrsturbo
May 25, 2008 08:40 AM
G2RSR
Jul 25, 2007 10:18 PM
Karlos G
May 25, 2007 08:58 PM
