Handbrake cable routing
Old Jul 29, 2019 | 02:49 PM
timsrs's Avatar
timsrs
Default Handbrake cable routing
Hi
can anyone post a pic of which way the handbrake cable routes
I've got a 6 degree beam and I’m sure a bracket has been cut
so if someone can post pic as I’m not sure which way it’s routed
many thanks
Old Aug 30, 2019 | 08:35 PM
mechanic28's Avatar
mechanic28
there should be two holes on each side to feed it through , I can take a pic if you still need?
Old Aug 30, 2019 | 09:42 PM
Adam-M's Avatar
Adam-M
I made my own little brackets as my 6 degree beam done away with the holes that the cable used to pass though near the diff
Old Aug 31, 2019 | 09:25 AM
dojj's Avatar
dojj
Resident Wrestling Legend
It's not so much a bracket as a tab on the arms
The adjuster bracket is in the chassis
mk2rstaff
Feb 18, 2011 06:35 PM
cfoster
Aug 19, 2009 02:07 PM
haz87
Jan 12, 2009 08:58 PM
Daveysaff
Dec 28, 2007 02:14 PM
plynchy
Nov 17, 2005 08:17 AM
