radiator fan switch
Old Jul 17, 2019 | 09:22 AM
Marc sierra's Avatar
Marc sierra
Default radiator fan switch
Yesterday I ordered a Escort Cosworth fan switch for my Sapphire 4x4, as I don't like the way the fans are working as standard. I also have the Escort fan switch on my 2.9 24v. On that car I have used a relay from a bug eye Scorpio to switch both fans in series (6V to each fan), so they only run at a low speed at the first temperature level of the switch (on at 95 degrees). At the second level (on at 100 degrees) both fans are switched in parallel (12V to each fan), so they run at full speed.
Normally the fan switch is located in the supply (hot) side of the radiator. One other thing I also changed on my V6 is to have the temperature switch in the return hose from the radiator. That way the fans only switch on if the return water is still too hot. On the V6 this seems to work perfectly.
The YB also has the switch fitted to the supply side of the radiator. To me this just does not make sense. Why would you want to switch the fan on when the water to the radiator is too hot? The radiator may still be able to cool it enough by the natural wind from driving, so there would not be a reason to switch on the fans. Only if the return water is still hot the fans should switch on. Or am I missing something here? As I can't believe Ford would have gotten this wrong...
Old Jul 22, 2019 | 10:37 AM
The design is over 30 years old.
I fitted an updated fan loom with an override switch inside.
I fitted a new switch to mine years ago. Then I went to ford fair got stuck in traffic and the car over heated. The switch was only a few months old.
Old Jul 28, 2019 | 09:15 AM
charlie luciano's Avatar
charlie luciano
I had loads of issues with the cooling system in my 4x4 Sapphire Cosworth when I first bought it, fitted upteen fan switches and still had overheating issues, turned out to be the radiator which was blocked, once fitted with a new rad from Ford everything was ok, ended up fitting all alloy bits and fans that run a lower flow of electrical current. Another problem is the wiring that ford used for the cooling fans is total pish and just not up to the job, if your fans run constantly eg when stuck in traffic the wiring gets hot and just melts, as Glenn says fitting an up rated fan loom is a must as the cars are getting on a bit now.
Escort MK 5 / MK 6
Nov 14, 2011 11:04 AM
philg12
May 27, 2011 03:56 PM
cossie330
Feb 9, 2008 09:12 PM
simonc
Jun 28, 2007 08:58 AM
michaelward
Jan 16, 2007 09:16 PM
