Knobs
Old Jun 26, 2019 | 07:48 PM
tosh's Avatar
tosh
Default Knobs
I thought by just saying knobs for the title then this would get more attention
I'm going to get the original gear knob leather replaced but was wondering if anyone knows if the top plastic gear number position cap comes off?
its the longer 2wd sapph one.
Old Jun 27, 2019 | 02:48 PM
Indyrs's Avatar
Indyrs
Mate
Don't try to take the top lettering plastic cap off as its stuck on with very old adhesive as the numbering and gear pattern will rub off, I tried this and messed it up. I have 2 spare gear knobs that I will be giving to Jack at royal steering wheels to do, not sure how he proposes to take it off or leather around the lettering.
I will update once mine are done
Regards
Indy
Old Jun 27, 2019 | 04:41 PM
tosh's Avatar
tosh
Thanks for that I’m glad I didn’t fire straight into it like I normally do as I thought it best to ask first.
the leather came of mine years ago and from memory I don’t think it went under the top cap, I think it just tucks into the small groove around it.
thanks again for that.
Old Jun 29, 2019 | 02:53 PM
tosh's Avatar
tosh
Thought I’d have a go at removing it as I had nothing to lose, so this is how I achieved it:
over about 4-5 hours I kept soaking it in hot water also adding boiling water to that to keep a Constant heat & occasionally using a plastic trim tool to push down the sides to wiggle it sideways a bit but avoiding leveraging it in the upward direction, I slowly started to notice water working it’s way between the glue and the back of the cap, when it looked like it was ready I prised it up gently and it came off, it has removed some of the black backing spray but has left the numbers intact so I will now try using some very fine wet & dry to sand off the rest of the black backing and then re spray it before getting the leather
re-trimmed. So fingers crossed.
BOMBGOD
Aug 10, 2005 08:40 PM
Wazzzer
14
Mar 15, 2005 08:58 PM
Daveyboy
Nov 24, 2004 10:49 AM
Mike Rainbird
Trader Parts for Sale.
May 19, 2004 09:12 AM
B11GNS
Mar 27, 2004 08:57 PM
