Alignment of camshafts
Old Jun 11, 2019 | 09:11 PM
Old Geezer's Avatar
Old Geezer
Default Alignment of camshafts
Hi all..another question please.
I have seen some query on the forum previously about setting up the camshafts for belt replacement and difficulty with alignment of the pulleys in accordance with the manual.
My 4wd Cosworth head has been skimmed, valves ground in and a new set of Burton hydraulic lifters fitted. The car has vernier type camshaft pulleys fitted which I have set to centre to simulate the original pulleys. The exhaust cam can be set so that the 'arrow ' lines up with the top of the head casting no problem although it tends to creep back.
The inlet cam however springs past this point by a tooth or so and can only be aligned by turning it back with a wrench and holding it against quite considerable pressure . The turning moment past the book set point seems to be caused by the spring pressure of the opening of the valves on no3 cylinder as the camshaft lobe slips off the edge of the tappet and the cam cannot rest at the correct set point. The situation occurs at every 90 degree turn of the camshaft so that it is not due to any one pair of valves or can lobes.
Previous comment seems to say that the belt can be installed by holding the pulleys in the correctly aligned position with a wrench but this doesn't seem to be right somehow and I am worried about getting the cam timing right.
Do others have experience of this problem and know what causes it?
Thanks
Many thanks.
Old Jun 23, 2019 | 02:06 PM
NZWINRZ's Avatar
NZWINRZ
Normal, most engines with 2 or 4 cams don't have a perfect resting spot to install the belt. A lot like BMW & Mercedes for example have special tools that bridge the cams on the head to install gears/chains on time. Like you said is to hold the cam in position, alien belt, apply tension to belt.
Old Jun 24, 2019 | 10:22 AM
Old Geezer's Avatar
Old Geezer
Hi...Many thanks for the advice. Wedged the cams in position, fitted the belt and hey ho it all started up with no problems. It's a pity that Ford couldn't do something like BMW or Merc...there's no mention in the manual of a procedure for positioning the cams in the event of this difficulty. I'm very grateful for your help.
tizer
Escort MK 5 / MK 6
Apr 1, 2005 10:01 PM
Lee_R21Turbo
Mar 22, 2005 06:14 PM
cosworthbg
May 29, 2004 04:10 PM
