Saff 4x4 starter issues
Posting here now , incase anyone had simular, as not looked into much yet
Sometimes the starter motor just seems to spin and not engange, and other times it does but get a grinding / catching noise as if the cars ingear.
All ive done so far is take the starter off and try it on its own with some leads. All seems to run ok and fires the cog out and returns without issue.
planning on cranking the engine round manually and inspecting all the fly wheel teeth.
Failing that, do i just spunk some cash on a new starter? or drop the gearbox and check the fly wheel and clutch is all good, tight and as it should be?
Check the engine earth, it could be high resistance giving weak power at the starter when cranking. Put a jump lead from the starter casing to neg on the battery, see if that improves it.
rst in breaking
24
Jul 20, 2010 02:14 PM
madcossie
Nov 24, 2006 07:18 AM
BillyCabrio
39
Sep 10, 2005 11:23 AM
L33 BYT
25
Oct 11, 2004 05:31 AM
