RST S1 turbo oil seals or not?
Old May 5, 2019 | 09:26 AM
Wade123's Avatar
Wade123
Default RST S1 turbo oil seals or not?
There is a breather hose that runs from the rocker cover breather direct to the lower side of the box, I've just cleaned the breather and removed a small restriction on the bend as the pipe had started to kink, but still 50% open.
Old May 5, 2019 | 01:27 PM
Wade123's Avatar
Wade123
Since cleaning, been on a 25 mile each way trip, came back and left to idle for 20mins, absolutely nothing from the exhaust, i will continue to monitor it for now
Old May 16, 2019 | 10:19 PM
fatty's Avatar
fatty
hello
I've always had a bit of oil / sludgy black stuff in the cross over pipe on mine. I think as long as you're not belching out blue smoke on boost the seals in the turbo should be OK.
Could be breathing a bit heavy if you've got it plumbed in as per factory.
Blue smoke on start up is normally valve stem seals.
BTW. don't be too scared of having a go at the turbo yourself..the kits are pretty cheap on ebay and its only a few little snap ring on the shaft.
Old May 17, 2019 | 09:46 PM
Wade123's Avatar
Wade123
Thanks, since improving the breather it has been ok so far
rsguy
Apr 21, 2013 07:30 PM
lukeyboy
Ford Escort RS Cosworth
Feb 25, 2012 10:41 AM
nigel b
Jun 9, 2004 09:27 PM
