RST S1 turbo oil seals or not?
Old 05-05-2019, 09:26 AM
Wade123
Wade123's Avatar
Default RST S1 turbo oil seals or not?
There is a breather hose that runs from the rocker cover breather direct to the lower side of the box, I've just cleaned the breather and removed a small restriction on the bend as the pipe had started to kink, but still 50% open.
Old 05-05-2019, 01:27 PM
Wade123
Wade123's Avatar
Since cleaning, been on a 25 mile each way trip, came back and left to idle for 20mins, absolutely nothing from the exhaust, i will continue to monitor it for now
Old 16-05-2019, 10:19 PM
fatty
fatty's Avatar
hello
I've always had a bit of oil / sludgy black stuff in the cross over pipe on mine. I think as long as you're not belching out blue smoke on boost the seals in the turbo should be OK.
Could be breathing a bit heavy if you've got it plumbed in as per factory.
Blue smoke on start up is normally valve stem seals.
BTW. don't be too scared of having a go at the turbo yourself..the kits are pretty cheap on ebay and its only a few little snap ring on the shaft.
Old 17-05-2019, 09:46 PM
Wade123
Wade123's Avatar
Thanks, since improving the breather it has been ok so far
rsguy
21-04-2013 07:30 PM
lukeyboy
Ford Escort RS Cosworth
25-02-2012 10:41 AM
nigel b
09-06-2004 09:27 PM
Quick Reply: RST S1 turbo oil seals or not?
