Ford Sierra diff 3.77
Old Apr 25, 2019 | 03:30 PM
Ian McLaren's Avatar
Ian McLaren
Default Ford Sierra diff 3.77
Hi all I’m a new member after some advice. I’m using a Sierra diff 3.77 for oval track racing and need a lsd for it. Crown wheel is 8 bolt. Standard Sierra crown wheel 10 bolt. Lsd will not fit middle of 8 bolt crown wheel. I could weld it to locked diff but that would ruin a rare diff has anyone no of a lsd that would fit this diff or had a standard Sierra lsd lathed to fit. Any help would be appreciated. Ian.
Old Apr 25, 2019 | 04:39 PM
Caddyshack's Avatar
Caddyshack
Bara Singh might know the solution. Bara motorsport 07970 197377.
a lot of people on here have swapped to the supra diff and many have used a 6 degree beam to improve traction / handling, would the rules allow that?
Old Apr 25, 2019 | 05:03 PM
Ian McLaren
Hi thanks for the reply I race sierras so running gear has to be ford probably get away with an after market lsd.
Old Apr 25, 2019 | 05:18 PM
Caddyshack's Avatar
Caddyshack
ah, ok. I did wonder if rules would restrict the use. See what Bara says about lsd for yours.
Mies
Feb 25, 2024 06:37 PM
carterhall14@hotmail.com
May 31, 2016 07:00 AM
FROMFIFE
Dec 2, 2010 12:33 PM
FletchCossie
Apr 10, 2005 12:20 PM
Rhys
Nov 10, 2004 09:59 PM
