Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
1997 ford escort 1.8 16v zetec fuelpump problem
Old Apr 18, 2019 | 12:02 AM
Brandon Baxter's Avatar
Brandon Baxter
Default 1997 ford escort 1.8 16v zetec fuelpump problem
Please i caunt get my fuelpump workiñg àfter i remove my mobilizer my fuelpump have only brown wires can some one please asist me what to do if i touch the wires at the cutoff switch the pump goes on but still not starting i also saw that i have voltage on both my fuelinjectors wires
Old Apr 18, 2019 | 05:03 AM
haz87's Avatar
haz87
You've obviously missed some wiring somewhere when removing the immobiliser. If you can get the fuel pump running permanently with the fuel cut bridged, then you obviously still have an open circuit on the ignition side. Retrace all the wiring you've disturbed basically
XR2Monkey
Aug 27, 2012 06:01 PM
trig_112
May 6, 2008 12:48 PM
Dan Si
Nov 3, 2007 11:57 PM
I8A4RE
Mar 24, 2006 10:08 PM
