cosworth tacho and cluster and ignition pulse question
Old Apr 1, 2019 | 05:52 PM
carbon1993's Avatar
carbon1993
Default cosworth tacho and cluster and ignition pulse question
Hello,
I am building a xr4i sprintex and want to use a cosworth tacho because of the boost meter. The tuner can make change the 6 pulse to a 4 pulse to work with the cosworth tacho.
But are these clusters interchangable? without changing the connector. I don´t wont to short circuit anything.
Also does the tacho react to a negative or positive pulse? Also kind of curious what the red wire does.
here some pics:
Old Apr 1, 2019 | 08:14 PM
martysmartie's Avatar
martysmartie
Negative, there is a circuit that runs the electronics, so red is a switched live.
Yellow is a trigger input to the IC, which drives the motor.
I recently diagnosed/replaced the former for someone.
As to the interchange question, the connectors are different between MK1 and 2, but imagine they are the same on MK1?
Martin
Old Apr 6, 2019 | 05:55 PM
carbon1993's Avatar
carbon1993
I get it. The red wire is there because they have cut out some of the print circuit. It fits right in the mk1 cluster.
thanks!
wheelwizardrefurbs
Aug 29, 2015 09:25 AM
ASHCOSSIE
Oct 24, 2009 07:09 PM
fast_ford_uk
Apr 21, 2008 05:11 PM
Mk5_XR3i_130
Nov 25, 2006 03:43 PM
