HOW HARD???
how hard is it to bleed a coolant system on a frst
it's doing my head in
the temp gauge is in the red
which is the best way to get rid
of air from the coolant system
yeah sorry
i should of explained more
i put new piston rings in, so basiclly a rebuilt on the engine, with
new gaskets etc also brand new cylinder head ( all proper ford parts)also it;s just had a new theromstat
there is loads of air but i was running it for about 20 mins and still shit
Personally. So I dont know specifically to your car.
Start from COLD
Fill system to the mark on the bottle.
Squeeze all the coolant hoses to try and shift the air around.
fill to the level again.
Repeat a couple of times
Start the car with the cap off.
Leave it idling
Engine will take in a fair amount of the coolant down into the block.
Keep the level on or slightly above the mark on the bottle.
Run the engine (idling) until the fan cuts in and out a few times.
Make sure the bottle doesnt run dry. Or you'll ahve to start again
Leave it to cool.
Check the strength of the coolant
Bung the cap on and take it for a quick drive.
Any Good
Start from COLD
Leave it idling
Leave it to cool.
Any Good
Originally Posted by Spax
also turn the heaters on hot and turn the speed on full this will help circulate the water and remove the air
sridgett
Oct 1, 2015 07:30 PM
The Youth.
Sep 30, 2015 09:59 PM
SMILER258
Sep 28, 2015 09:04 AM
