3dr cos supra diff install
Old Mar 26, 2019 | 10:42 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Default 3dr cos supra diff install
3.9 Supra Diff
Mk fitting kit
MT Motorsport cover
Adrenaline & OMP rear strut braces
Adrenaline brace bolts through the floor and into the diff hanger.
Im not a mechanic but helped my mates do the work over at thier Garage. The Grease Monkey
More of a job than we anticipated with lots of fettling checking adjusting cutting finnessing as is often the way with modifying stuff.
The diff takes around 1.5ltr of oil and your looking at Ł15 a litre for a quality oil.
I need to get the exhaust modified a touch as sits to close and catches the propshaft at the nose of the diff, otherwise everything seems good and I am very pleased with the result and general fit and finish of the kit parts. More urgency in the power delivery with the 3.9 ratio. Will be testing fully in the coming months
Old Mar 27, 2019 | 07:27 AM
Caddyshack's Avatar
Caddyshack
Looks great, who made the drive shaft adapters, not seen them with cutouts round the nuts like that before.
Old Mar 27, 2019 | 10:01 AM
Mad_Mat's Avatar
Mad_Mat
New Owner
MK adapters those mate.
Old Mar 27, 2019 | 10:08 AM
Mad_Mat's Avatar
Mad_Mat
New Owner
Old Mar 27, 2019 | 10:24 AM
smiley's Avatar
smiley
Nice one
Old Mar 27, 2019 | 10:41 AM
Mad_Mat's Avatar
Mad_Mat
New Owner
Originally Posted by smiley
Nice one
Cheers mate. Long day in the workshop to fit it up. Old diff was clonking and knocking had loads of slop in it. Everytime i planted it would be thinking the diff is about to go bang. Should be good for more power and to lay some rubber down now.
Old Mar 27, 2019 | 12:10 PM
smiley's Avatar
smiley
Yes least you know your bullet proof in that dept all this to come on mine
Old Mar 27, 2019 | 02:20 PM
Caddyshack's Avatar
Caddyshack
Thanks...shows how long ago I looked at my ones then!
Old Mar 27, 2019 | 07:55 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Can anyone confirm if i have used the right diff oil?
Been looking on a couple of supra forums. Seems everyone has a different recommendation or preference.
Seemed to drive fine. Will see what its like after some stick and heat in it.
What are you guys using in yours?
Old Mar 27, 2019 | 09:19 PM
Caddyshack's Avatar
Caddyshack
Bara told me ANY ls oil is fine...as you say there are many opinions.
Old Mar 27, 2019 | 09:29 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Bara told me 80/140 slipper oil I got Castro stuff from jaguar they keep it on the shelf. Seems they tell different people different things they told me when I got it over hauled by them and the up rate kit fitted
Old Mar 27, 2019 | 09:38 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Thanks chaps
Old Mar 27, 2019 | 09:41 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Yes chop chop its literally been years now in the making
Old Mar 28, 2019 | 03:17 PM
smiley's Avatar
smiley
Try 8 being realistic probably 10
Old Apr 2, 2019 | 05:29 PM
R4N SS's Avatar
R4N SS
be interested to hear your feedback as i have a supra diff sitting on the floor in my garage and parts of a beam lol
Old Apr 2, 2019 | 08:45 PM
james kiely's Avatar
james kiely
looking good matt
Old Apr 2, 2019 | 09:29 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Seems to be all good at the mo. I put new tyres on the rear just before fitting the diff and i think the tyres have impacted the high speed balance. Front tyres are possibly getting on 10 yrs old and rubber has gone hard. At least i think its the tyres and not the diff i am pretty sure it is the tyres unless anyone else has experienced similar with this conversion?
looking good matt
Cheers James
Old Apr 2, 2019 | 09:35 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Old Apr 2, 2019 | 09:36 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
New Header tank installed as well. Old cossie getting some love
Old Apr 23, 2019 | 01:20 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Supra diff drain plug
Changed the oil to motul ls300 75/90w and that's sorted out the unbalanced handling characteristics it had before.
So chaps for reference definitely use a 75/90 ls oil in your Supra diffs.
I'm going to change it again after a few miles and hope the swarf is minimal.
Old Apr 23, 2019 | 03:05 PM
R4N SS's Avatar
R4N SS
has the diff affected your speedo - is it still accurate?
Old Apr 23, 2019 | 04:14 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
It's not miles out. I am running 17" wheels though so the rolling radius is probably a touch bigger than standard.
At a guess it's about 10% out.
Old Apr 23, 2019 | 04:16 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
That's not a complete guess I did do a side by side with another car at 60. Mine read 65 the other car 60.
I will gps it at some point. Be good to know exactly how far off it is
Old Aug 2, 2019 | 05:38 PM
Thomas newton's Avatar
Thomas newton
Am just about to put a supra diff in my 2wd saph anything to look out for or any major surprises wal doing it mate
Old Aug 2, 2019 | 11:46 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Its a bit of a fiddle. I think one of the main things i hadnt really considered is the exhaust needs modifying to clear the diff properly.
We heated mine red hot, then with a suitable die squashed it in a large press to ovalise the pipe. Worked a treat to.
Don't cut any corners. If your using a fitting kit get a MT rear cover to ensure nothing breaks. I've found motul 75/90 ls300 diff oil pretty good and I've tried a couple now.
It has changed the handling characteristic of the car a little. Bit less stability on the rear when pushing on. Could just be my diff though. Got mine off ebay and it could possibly do with a refresh at some point.
What ratio is yours? As others have found previously the 3.9 is a real sweet spot for fast road.
xr4x4rs
786
Apr 13, 2016 09:36 PM
COCHYN
1205
Dec 19, 2015 07:57 PM
ginner
20
Oct 12, 2012 09:46 PM
Turbosimpsons
51
Nov 11, 2011 05:30 PM
Sonic Boom
11
Dec 9, 2008 10:13 PM
