Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
2006 1.8tdci very random crank no start
Old Mar 17, 2019 | 02:27 PM
oldboy's Avatar
oldboy
Default 2006 1.8tdci very random crank no start
Very randomly, 3 times in the last six months my car will crank and not fire. The conditions are always first thing in the morning. It has never cut out/stalled while driving. It will initially start as normal, then stop. It will then require a 'lot' of cranking, eventually putting up the message 'engine system fault'. But, keep cranking and it will fire and then operate as normal for weeks/months. No codes showing/pending, no leaks, regularly serviced (Oct 2018). Goes like a train in all other respects.
Any help would be gratefully received!
Thanks
Old Mar 17, 2019 | 08:34 PM
oldboy's Avatar
oldboy
Answering my own question here but the car was serviced just before I got it and I wonder if the fuel filter has been fitted correctly, ie the rubber seal?
Old Mar 17, 2019 | 09:29 PM
james kiely's Avatar
james kiely
have you had the car plugged in to see what fault its logging?
Old Mar 17, 2019 | 09:30 PM
GVK.'s Avatar
GVK.
your non-start would be more often, even all the time if that was the case.
If the engine malfunction message has shown on the dash there will be a fault code.
Have you been checking the on-dash self diagnostics? They aren't much use.
Old Mar 17, 2019 | 09:51 PM
oldboy's Avatar
oldboy
No EML. No fault codes, no pending codes.
Old Mar 18, 2019 | 04:35 PM
oldboy's Avatar
oldboy
Just had a mate with a 'Delphi' diagnostic pull a code P0089 Fuel pressure control valve - Signal is above maximum threshold.
It's been running fine today, but that code was logged. No EML showing.
Again thanks
Old Mar 18, 2019 | 08:19 PM
GVK.'s Avatar
GVK.
Make sure fuel filter is good
leak off test on injectors
No leaks on fuel pipes/hoses
Old Mar 18, 2019 | 08:24 PM
oldboy's Avatar
oldboy
You do tend to get some diesel around the engine but the only place I've noticed some 'wet' is on the plastic pipes where they loop around under the brake reservoir? Can't see anything obvious but its there all the same. Is there a guide on here regarding the 'leak off test'
Thanks
Old Mar 18, 2019 | 08:36 PM
GVK.'s Avatar
GVK.
I may have posted up about leak off tests on here in the past, ideally you need a special tool which is 4 calibrated bottles and pipes to measure the leak off.
I'll see if I can find my old posts.
Old Mar 18, 2019 | 08:41 PM
GVK.'s Avatar
GVK.
https://passionford.com/forum/6302016-post6.html
https://passionford.com/forum/genera...not-start.html
http://www.bba-reman.com/forums/topic95757.aspx
Measure diesel injector return quantityStart engineLet engine run until one of the measuring cylinders is filled completelyStop engineThe maximum permissible return quantity is 3x as large as the smallest return quantity measured
Measuring cylinder of injector
Contents
41 ml
44 ml
50 ml
46 ml
Maximum permissible return quantity:
41 ml x 3 = 123 ml
All the injectors are in good order.
Example not okMeasuring cylinder of injector
Contents
50 ml
18 ml
18 ml
10 ml
10 ml x 3 = 30 ml
Injector 1 has too large a return quantity. It must be replaced.
The format is a bit pissed on here but you get the idea.
bostjan
Jan 30, 2018 05:40 AM
stormingthor
Ford Focus Diesel
Apr 24, 2016 09:25 PM
davetdi
May 5, 2011 10:30 PM
Ginge !
18
Dec 2, 2004 08:58 PM
DOO
24
Sep 23, 2004 09:17 PM
