Ford cosworh Sierra Hard Brake Pedal
I have my Ford Cosworth Sierra sitting in shed for 6 months and when i went to drive it the brake pedal was rock hard,What can the problem? ABS unit? Can it be the black switch?Has anyone have this problem before? Help
The problem = pump not operating.
The first check would be to check the supply to the pump (i.e. fuse/relay issue) but there are several possibilities, which include pressure switch, seized pump, but check the basics first and that is the first thing I mentioned.
Martin
Martin
florent78
Alloy wheels and ICE for sale
Apr 2, 2010 06:40 PM
Scott-rs2k
Jan 13, 2006 03:18 PM
