Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Mk3 fiesta - 2.0 engine swap
Old Feb 25, 2019 | 11:14 PM
Coolpurplelights's Avatar
Coolpurplelights
Competent
Default Mk3 fiesta - 2.0 engine swap
Hiya
i have a 91 fiesta with the 1.3 hcs lump in, and after some research I’ve decided I want to put the 2.0 lump in. However I have a few questions I couldn’t find any answers to.
1. What should I do about engine mounts when it comes to putting the 2.0 in?
2. What should I do in regards gearbox? Use the original or use one from something else? And if something else, what should I do regards mounts?
3. Should I decided I’d rather the 1.8, what car/year should I try and get one from and again, what’s the engine mount situation like?
i know that I need a load of 1.6/1.8 engine parts to make the 2.0 work correctly, doing that isn’t an issue.
Ta in advance
Prickly_buzz
Apr 2, 2017 03:46 AM
bam69375
Oct 29, 2010 09:26 PM
whipsey
Fiesta RS1800/RS Turbo
15
Nov 11, 2008 01:03 PM
rowen20
Jan 11, 2008 08:05 PM
