Help needed, whats the best turbo for my engine spec
Old Feb 22, 2019 | 09:33 PM
makaveli96's Avatar
makaveli96
Default Help needed, whats the best turbo for my engine spec
Hi guys, was wondering if anyone can give me some good advise I'm looking to upgrade my Turbocharger on my 1990 S2 RS Turbo, I'm after something that has good strong power but with minimum lag as possible, at the moment it's pushing out 186bhp with 205ft @ 15psi before the Cylinder head work was done and don't want to go over 15psi with the new Turbo as I want to keep the reliability up, here's a run down on what's been done on my engine. Thanks
Engine Spec =
Stage 2 Cylinder head, Kent CVH 34 Camshaft Kit, Group A Ignition Coil, Magnecor 8mm Blue Ignition leads, K&N Air Filter, Bleed Valve, Bailey Dump Valve, Bailey Oil Breather, Bailey Header Tank, Full Samco Boost Hoses, Full Samco Coolant Hoses, Full RooseSport Ancillary & Oil Hoses, Pace Aluminium Uprated Radiator, Radtec Front Mounted Intercooler (will have twin Kenlow fans fitted with the new turbo) Airtec Turbo Cooler, JamSport -31 Actuator, Uprated Bosch 941 Fuel Pump, T304 Stainless Steel Tubular Manifold (From Auto Specialists) Full Scorpion Stainless Steel Exhaust System with a 4” rolled out tail pipe and a Helix 4 Paddle Clutch Kit fitted. The Bottom end is all standard
Old Feb 22, 2019 | 09:43 PM
Rsmat's Avatar
Rsmat
Here's my spec..made 253bhp and 303ftlb at 1bar of boost and get quick spool and power at 3k
EFI block
EFI Flywheel with ARP bolts and CPS.
PEC Rods
Wossner Pistons
Ford Crank .
King Racing bearings.
Brand new s2 Ford oil pump
Gated and baffled sump
S1 modified inlet by A.H Fabrications.
cosworth PF09 TPS
brand new cosworth ISCV
Airtec Radiator
Pace Rs500 style single pass intercooler.
Deka 60lb 630cc injectors
Mac 3 port electronic boost controller.
Fiesta Turbo electronic drive speed pick up (gearbox)
Vauxhall 3 bar map sensor.
Simtek Pro engine management.
Zeitronix zt-2 engine monitor and data logger.
Motor sport Traction control.
Boost By Gear .
AL Developments big port cross Hatch head.
Inlet match ported by A.L Developments.
Harland sharp Roller Rockers.
Newman PH4 cam 200lb springs and solid lifters.
Fiesta Turbo coil pack with fiesta turbo leads.
ND Fabrications over the box exhaust manifold.
ND FABRICATIONS down pipe and bracket.
Mongoose-down pipe back and 3" back box.
TURBO - honeywell Garrett GTX2867R GEN 2.
AP racing cp2000-35 clutch kit.
IB5 Gearbox with Quaife diff shot peened Gears.
Rally design quick shift kit linkage .
AP racing Front brakes.
cosworth 2wd Rear brakes.
Mocal 16 row oil cooler
A.H Fabrications breather catch can.
mk5 escort clutch peddle and billet quadrant.
Old Mar 4, 2019 | 07:41 AM
cabrst's Avatar
cabrst
ill say a stage 2 but a standard will do fine as you are on standard chip
Old Mar 4, 2019 | 11:44 AM
turbotrev's Avatar
turbotrev
Is it more power your after hence wanting to change the turbo?
if so you may wanna look at changing the rods as if your gonna be up around that 250hp mark soon your pushing it on the standard rods, they are made of chocolate
Cheers Paul
Old Mar 12, 2019 | 11:31 PM
makaveli96's Avatar
makaveli96
Hi, I've got an Evo chip fitted, if you read the description I'm not running on standard power
Old Mar 18, 2019 | 01:59 PM
cabrst's Avatar
cabrst
I cant see in text what chip, so asumed it was standard
But anyway a stage 2 will do the job ( thats what i run on mine with close setup as you ) I do run a full tubelar exhaust and mod xr3i inlet and newman cam and a AB chip
Old Mar 19, 2019 | 09:49 PM
makaveli96's Avatar
makaveli96
Cheers Paul
Sorry for the late reply, well my turbo seals are leaking and is getting worse so might as well upgrade it, not looking for major power I'll be happy at around the 200 mark, so where would be the best place to buy one and do you think a stage 2 is more than enough as I don't want much lag
Old Mar 19, 2019 | 09:51 PM
makaveli96's Avatar
makaveli96
And not looking to raise the boost any higher than 14-15psi as the bottom end is standard and original
Old Mar 22, 2019 | 04:20 PM
Rsmat's Avatar
Rsmat
My Turbo did 253bhp and 303ftlb at 14psi .
Old Jul 25, 2021 | 08:23 PM
jcarpenter's Avatar
jcarpenter
cracking build, been on the forum for years,never registered, just never posted as my build hasn't been worthy of a thread. looking forward to more progress.
Justin
Old Jul 25, 2021 | 08:30 PM
jcarpenter's Avatar
jcarpenter
Unhappy
Justin
ignore this somehow posted on the wrong thread
Rsmat
2551
May 22, 2024 04:42 PM
rsmark86
Aug 6, 2010 05:36 PM
Matt_fez
52
Mar 2, 2010 03:36 PM
ldack
Mar 12, 2006 09:28 PM
