S2 ERST 2.1 ZVH FLYWHEEL HELP.... !!
where can i get a BRAND NEW flywheel for a 2.1 ZVH ERST... ?
its basically a 1.6 CVH flywheel that is required...
where from please ? and prices ?
thanks in advance people !
you reckon it will be that easy ?
CVH EFi arent that common, i thought
have been told any 1600 CVH flywheel should do it...
dont know where i would get it machined either, thats another potential problem
Any CVH flywheel will fit - however if you are running any sort of EFI system, the chances are you wil NEED the EFI flywheel.
You could machine it yourself, but it is a real hard, slow job. Ligtening and balancing is a pro job only though. Any machineshop should be able to bore the holes out, but lightening and balancing I'd only entrust to a specialist with years of experience and a good rep.
Mc5506
Oct 5, 2015 09:57 PM
