Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Focus 1.8 misfire
Old Feb 5, 2019 | 07:03 PM
Mournblades's Avatar
Mournblades
Default Focus 1.8 misfire
I recently bought a 2004 focus 1.8 ghia. It has a misfire on cylinder 1. I knew about that when I bought it, code was giving a fuel injector problem.
I've changed the injectors, and it made no difference except now I'm just getting a 301 error. Changed the plugs, leads and coil. Still no change. My next step (when I get time) is to run a compression test. But...
The temperature gauge is acting strange. It takes quite a while to reach normal operating temperature then when it does, if I sit in idle, the temperature gauge rapidly drops down to about the quarter mark but picks back up to the halfway on increasing revs. Any ideas?
nathyj01
Dec 6, 2014 10:09 AM
Dazababes
Dec 11, 2009 02:42 PM
stevierob
Ford Focus RS
Jul 16, 2009 11:32 PM
animal_417
Ford Focus RS
Apr 19, 2007 08:09 PM
Ford Focus RS
Mar 14, 2004 07:36 PM
