I was wondering if a ST170 exhaust manifold (aftermarked) fits on my mk1 Mondeo 2.0l zetec silvertop?
If not, what do I need to make this work or is there any aftermarked manifold that fit on this car without a lot of modifying?
The main differance is the bearing caps and bolts. The silvertop has much thicker main bearing caps around 20mm. These hit the cast part of the blacktop sump. It’s a combined windage tray / block ladder and sump all in one.
To get to fit you have to grind away where it touches
