Thought I'd share my first ever restoration with you that I've been doing for the past 3 years. The car started as a lowish mileage G plate car that was an honest car that needed some work. I bought it as below where someone had the intentions of doing it but gave up part way through.
Initially my plans were to paint it myself as I had never painted a car before and just have a tidy car for messing about in.
So here she is when I bought her
When she was nearly finished
So lets begin, some more of when I got the car
After an initial inspection all appeared good, a solid car that retained it's original panels, no major rust and no signs of any damage. So the strip down for paint begins
Not too bad for a noob. This gave me the confidence to tackle the rest of the car. My thoughts were " well if it goes wrong I'll pay to have it painted "
So after painting the outside, I decided to do the underside. I purchased a spit for Ł100.00 and made a start stripping off parts which led to hours of sanding with a wire wheel, priming and painting
After the underneath was completed I turned my attention to the boat anchor in the front. Full strip down and inspection which revealed no issues, so all new gaskets and a lick of paint
Mate she looks lovely. Really well done on the paint work mate I want to do mine so will have to lňok up and see loads of vids. Altho I just need to do the underside. Have you still got your spit?
Best of luck with your restoration job. Fair play to you for spraying that car for your first time with a spray gun. It looks good in the photos. Must look better in the flesh.
