Setting ignition timin 2.0 Dohc
Hi everyone,
after I have bought me a second hand engine for my sierra I was curious about how to set my ignition timing on the standard ecu? The engine will run on lpg and a bolt-on turbo kit. My plan was to run the car as a daily due to the daily distance I make everyday.
I have heard that setting the ignition timing on the standard ecu is not possible but I am not really sure about that.
Can anybody help please?
Thanks in advance
Thanks in advance
The map-sensor of a standard non-turbo engine can't measure boost pressure.
So, your engine will be running very lean, once the turbo kicks in.
Also, the ignition timing is not adjusted for the boost and will be too early.
Running lean combined with a too early ignition will destroy the engine in a very short time.
I am adapting a Mercedes SLK supercharger to my Sierra Dohc and I am trying to delay the ignition by taking the two octane adjustment pins to ground but I do not notice that it delays the advance, I am measuring it with a strobe lamp and I do not notice anything.
(My idea is to use an Arduino to connect those pins to ground when it goes over 0.15 bars and activate a 5th injector, more or less like turbotechniks did)
What I can be doing wrong? I am joining the two wires (brown/blue and brown/red from the 3-pin connector that are next to the coil) to each other and then to ground.
Thanks in advance! And sorry for my low level of English
HirenRS
May 11, 2011 07:14 PM
Karlos G
23
Oct 8, 2009 02:54 PM
