Spec r type intercooler core
Old Jan 5, 2019 | 11:05 AM
stevecfrst1's Avatar
stevecfrst1
Default Spec r type intercooler core
does anyone know where you can buy the spec r bar and plate type intercooler cores from? Not having much joy getting hold of spec r and I’ve heard they have very long lead times so i wanted to look into getting my own core and having a fabricator make the end tanks and pipework. Thanks
Old Jan 5, 2019 | 12:59 PM
jonfoc's Avatar
jonfoc
Don’t they use Garrett cores? Mark Shead recommended CSF Race cores. Have a look on their website they were very easy to deal with.
Old Jan 5, 2019 | 02:38 PM
stevecfrst1
Yes I think they do, thanks for that. Don’t suppose anyone knows the size that you need?
Old Jan 5, 2019 | 03:22 PM
jonfoc's Avatar
jonfoc
What size do you need for what? You're the person that knows what you want it for!
Old Jan 5, 2019 | 03:54 PM
Caddyshack's Avatar
Caddyshack
If it’s for a Sierra or Escos then could could prob go for 100mm thick (front to back) and then use the airtec dimensions for their cooler which is similar to rs500 size
Old Jan 5, 2019 | 05:24 PM
stevecfrst1
Sorry I should of mentioned its for a sapphire cosworth and will be around 550hp, i was thinking they were all a pretty standard size. Thanks
Old Jan 5, 2019 | 05:27 PM
stevecfrst1
Cassyshack, not sure if you know but the spec r coolers are way smaller in height than a typical rs500 sized one, there probably less than half the height.
Old Jan 5, 2019 | 05:40 PM
Caddyshack's Avatar
Caddyshack
yes, some are. My one is actually larger but it was built for over 730 bhp. The benefit of the smaller ones is that they allow more air for the air filter and less lag in theory.
Old Jan 5, 2019 | 06:35 PM
jonfoc's Avatar
jonfoc
I'd be asking reputable tuner like Mark Shead or Stu at MSD for advice mate
Old Jan 6, 2019 | 09:20 AM
charlie luciano's Avatar
charlie luciano
And if and when you fit a 100mm spec r cooler don’t forget the radiator brackets to move the rad back otherwise the rad won’t bolt back up/fit
Old Jan 6, 2019 | 11:52 AM
Caddyshack's Avatar
Caddyshack
I think the 100mm airtec cooler is very good for the price, I had one and it massively lowered the intake temps compared to my rs500 one, they are very heavy but do come with a kit to make it fit. That one is lower and allows for a turbo aftercooler space too if needed.
Old Jan 7, 2019 | 10:37 AM
turbotrev's Avatar
turbotrev
What they lack in frontal area they make up for in depth hence the higher rated hp coolers are twice as thick as the 500 style ones.
The spec-r coolers use a garrett bar and plate style core, the best out there.
For 550hp i woulnt say one that spec is really needed but if moneys no object then of course its a better cooler
Cheers Paul
Old Jan 7, 2019 | 11:25 AM
Mark Shead's Avatar
Mark Shead
Cheers Paul
It is indeed needed at 550hp as they take 40c off the inlet temp. One of the best mods you can do.
Mark
Old Jan 7, 2019 | 05:19 PM
stevecfrst1
Mark is there any advice you can/would give me on what core size to buy and where to get it please? Is it something you have been getting made yourself? I literally cant get hold of spec r on the phone or email and even if I could people are telling me to expect 6 months to one year waiting time. Thanks
Old Jan 7, 2019 | 05:39 PM
jonfoc's Avatar
jonfoc
As I said earlier mate, Mark recommended CSF cores to me. I'm sure a fellow forum user can measure their core for you. Then go on csf site and buy the one you need. It's very easy to find the one you want.
Old Jan 7, 2019 | 05:43 PM
turbotrev's Avatar
turbotrev
Mark
I stand corrected then.
Mark would the airtec 100mm version not be fine for around the 550hp mark then?
Cheers Paul
Old Jan 7, 2019 | 05:45 PM
Mark Shead's Avatar
Mark Shead
Cheers Paul
The top feed Airtek will work at that level with no problem. I was referring to the stock RS500 style coolers.
Mark
Old Jan 7, 2019 | 06:34 PM
turbotrev's Avatar
turbotrev
Mark
ahh ok, I was meaning at 550hp ish a normal 500 style airtec one or the 100mm airtec version would be ok (especially that they are a quarter of the price of the spec-r one)
i know the spec-r ones are the best and the original 500 ones are crap lol
Cheers Paul
Old Jan 7, 2019 | 06:38 PM
Mark Shead's Avatar
Mark Shead
Cheers Paul
Any of the rs500 no matter who’s make struggles at 550hp other than the massively thick pro alloy one there normal struggles just like the rest.
Mark
Old Jan 7, 2019 | 07:19 PM
Caddyshack's Avatar
Caddyshack
I used to get over 30 degree c intake temps in summer using the 100mm airtec, not sure if that is all that high and if the spec r would be hugely lower? I suspect nearly another 100 bhp would have benefitted from the better cooler.
Old Jan 7, 2019 | 07:53 PM
scoooby slayer's Avatar
scoooby slayer
Cheers Paul
Hi mark, do you know the dimensions of my intercooler core in rods car ? Just curious this thread made me think of it
Old Jan 7, 2019 | 09:06 PM
dan le moignan's Avatar
dan le moignan
Iam on a normal airtec rs500 cooler (old style one) and don’t see over 30 degrees in the summer, Usually 28 degrees.
Only on a T34 though.
Old Jan 7, 2019 | 10:01 PM
turbotrev's Avatar
turbotrev
the 70mm thick version?
if so that’s what I used to have in my car
Cheers Paul
Old Jan 7, 2019 | 10:15 PM
dan le moignan
Think so Paul, apart from heat soak at a standstill it never goes over 30, not sure is that’s a good temp?
its with a t34 holding 27 psi
Old Jan 8, 2019 | 09:14 AM
Caddyshack's Avatar
Caddyshack
My car was at 36 psi and there was prob some heat soak to be fair and it was a very hot summer
Old Jan 8, 2019 | 04:03 PM
Mark Shead's Avatar
Mark Shead
I think from mem you where knocking on 60c.
Mark
Old Jan 8, 2019 | 04:29 PM
Caddyshack's Avatar
Caddyshack
Mark
‘that was on the previous 500 cooler that I gave to jonfoc, you mentioned it being over 50 and that is why I went airtec which dropped to 30’s and then I bought spec r huge Jobbie but have not had the car to try that one, it was on the 700 bhp Wrc Fiesta.
turbotrev's Avatar
turbotrev
Mark
depending on the compression of his engine would that of helped?
so say you ran a not so efficient intercooler but had a really low comp engine would that help it?
Cheers Paul
Old Jan 8, 2019 | 05:35 PM
Mark Shead's Avatar
Mark Shead
Cheers Paul
you have a wider tuning window on a low comp engine. For example a high comp will probably get to 50c and it falls off the mountain with power where on a low comp you may get to 60 to 65c before it does the same.
You would be mad to build a engine just because you wanted a cheap intcooler.
Mark
Old Jan 8, 2019 | 11:26 PM
turbotrev's Avatar
turbotrev
Mark
oh I know that!
just wondered if that factor would make much difference but that’s quite a bit more than I thought tbh!
Cheers Paul
Old Jan 9, 2019 | 09:19 PM
Rsmat's Avatar
Rsmat
I'm going to use a CSF core on my Rs turbo .
Old Jan 10, 2019 | 06:41 AM
20/20 vision's Avatar
20/20 vision
From: it's not where you are, it's where you've been and where you hope to be
how are these inlet temps being measured?
in a Cosworth how much impact does the positioning of the air temp sensor in different plenum designs have when these inlet temps are being measured?
my YB kit car has a stock plenum with 14mm spacer and stock location of stock air temp sensor. due to the resticted bonnet space, the plenum itself suffers lots of heat soak from the cylinder head or hot radiator air passing it on the way out.
under heavy use, inlet temps go to 40c max but on coasting after a thrash (so theres no air going into plenum to cool the sensor) it heat soaks from the plenum and inlet temps are reported up to 60c but as soon as the throttle is opened again (even slightly) they drop down to ambient + about 10c. however, the drop takes about 2 seconds or so and meanwhile the ecu is pulling timing.
i logged another temp sensor placed in the intercooler outlet hose and that's a much better solution.
do cossies have this heat soak issue?
Old Jan 10, 2019 | 09:43 AM
Caddyshack's Avatar
Caddyshack
I think you are doing what most people do and most people would suffer from some similar heat soak...although Mark Shead will be the authority on this thread to answer. I think I saw that Rod was measuring right at the point of entry and exit on the intercooler at one point which would be the best I guess.
pete mcrash
15
Oct 29, 2009 05:53 PM
Thrush
Computers, Consoles and I.T.
20
Jan 7, 2008 05:44 PM
Gartrac Mike
Jul 20, 2006 01:42 PM
Gartrac Mike
Jun 30, 2006 01:27 PM
Stavros
15
Jul 9, 2004 05:26 PM
