4-caliper + handbrake rear?
How have you solved the problem with the handbrake back when you switched to larger calipers?
I'll switch to the 330 front and 300 rear and must replace calipers front and rear, but must also retain the hand brake wire.
Is there anyone that uses both 4-calipers and original calipers only for handbrake? How did you mount it?
Regards/Jonas
Regards/Jonas
I MUST replace. I'm gonna make a registration on the car, and need to change all brake system. But I can use the original caliper for the handbrake.
Alternatively, a caliper with handbrake from start.
In front I got Brembo 4pot and 330mm discs. No abs, just double headcylinder.
Regards
Regards
dingla rs
Jul 10, 2016 06:02 AM
original
Sep 15, 2012 06:41 PM
Mad Matt
27
May 13, 2009 10:46 PM
redrsmk5
Ford Escort RS Cosworth
Oct 28, 2007 09:49 PM
antony215
Oct 11, 2006 07:19 AM
