3dr Sierra Cosworth with or without running gear
Old Dec 9, 2018 | 09:14 PM
3drRich's Avatar
3drRich
Default 3dr Sierra Cosworth with or without running gear
I’ve recently purchased a black 3dr Sierra Cosworth that has recently gone through a insurance claim due to Minor damage (now repaired) so it is on the hpi list and was also cat c back in 2003 which I don’t know what for as all the panels on the car are original from what I can tell. It is a complete car and as far as I can tell nothing is missing, it looks standard from the outside apart from it’s on coil overs and has a stainless exhaust. It’s a very quick car but has no paperwork at all apart from its current mot which is out in may next year. It’s showing 10k miles but has been around the clock. Engine wise it has a t34, genuine RS500 8 injector inlet manifold, alloy rad, inter cooler and turbo cooler.
Usual headliner sagging, needs a good clean but is all there. In my opinion this a good entry level 3dr that you can get in and use. The paint looks good and more than acceptable but I would want it resprayed if I kept it as theres bits all over it, the shell is solid and as far as I can see only one of the seat mounts is a little soft and about an inch of the drivers rear arch is a little bit crispy under the kit, I would say it’s had welding in the past due to the mot history saying the rear spring mounts where corroded but I can’t actually see any visible signs.
The running gear is very good apart from the engine does have the usual tapped noise and also there is a bottom end noise (not bad) which could be big/small ends but been like this for a longtime and never got any worse but it’s diffcult to pin the noise down without pulling it apart.
Car came to me repaired and although this will be a running and driving car with mot please expect that you are buying a potential project that will need bits and pieces in due course as after all it is 30years old.
Im not advertising this anywhere else as to be honest if it doesn’t sell I will keep it I just have to many projects and limited on space unfortunately. Please no time wasters, I won’t be giving out the reg number unless you are deadly serious, I can email pics/videos if required.
I would consider selling the car without engine, gearbox, diff, engine loom, Ecu, all rads/tanks and hoses in engine bay
Price is a firm £25000 complete or £20000 without the above.
Cheers.
Old Dec 9, 2018 | 09:19 PM
3drRich's Avatar
3drRich
Old Dec 9, 2018 | 09:20 PM
3drRich's Avatar
3drRich
Old Dec 11, 2018 | 03:15 PM
ede's Avatar
ede
Looks a nice clean car
any under side pics?
Old Dec 11, 2018 | 05:42 PM
smiley's Avatar
smiley
Can't believe it hasn't gone tbh
Old Dec 11, 2018 | 06:50 PM
3drRich's Avatar
3drRich
I haven’t at the minute but will put some up the weekend.
Old Dec 11, 2018 | 06:53 PM
3drRich's Avatar
3drRich
The usual bombarded with messages but no ones even looked at it and I haven’t got time for all that crap.
Old Dec 11, 2018 | 09:08 PM
rsminter's Avatar
rsminter
Interested if you still have it, once i sell my mk1 escort Cosworth,
unless you would be up for a deal with it.
Old Dec 12, 2018 | 05:35 PM
3drRich's Avatar
3drRich
Got any info on the mk1?
Old Dec 12, 2018 | 08:13 PM
rsminter's Avatar
rsminter
Sure... I don't want to hijack your for sale advert,so will pm you a pic and rough spec
Old Dec 12, 2018 | 09:52 PM
rsminter's Avatar
rsminter
cant work out how to pm a pic
Old Dec 14, 2018 | 09:28 PM
cossynut2's Avatar
cossynut2
10 Year Member
Mk1 Escort with Cosworth power sounds like a top car to me, suprised you want to sell it?
Old Dec 16, 2018 | 09:58 PM
rsminter's Avatar
rsminter
Just not using it mate...its not turned a wheel in 4 years,
so looking for a more useable classic.
Old Dec 17, 2018 | 09:32 PM
cossynut2's Avatar
cossynut2
10 Year Member
Your car so it's up to you but I don't get why you think your Escort is not a useable car? A lot of Cosworth 3 door owners hardly ever use them for fear of theft or putting miles on them as well. If your Escort is a nice well sorted one you should'nt have much trouble selling it.
Old Dec 29, 2018 | 05:41 PM
jim_robson's Avatar
jim_robson
Won't put the full reg but does it end in Ubh?
Old Jun 18, 2021 | 10:40 PM
mak147's Avatar
mak147
hi mate... i dont suppose you still have this car.
lee81
Jun 17, 2021 05:46 PM
timb551
Sep 24, 2007 07:48 AM
Ginge !
16
Nov 15, 2004 11:59 AM
NotoriousREV
Oct 4, 2004 05:52 PM
