YB Cosworth
Old Dec 1, 2018 | 12:37 AM
Spanky69au's Avatar
Spanky69au
Default YB Cosworth
Hi Guy's l have a yb coswoth turbo in a MK1 escort and am asking if anyone can tell me where the heater hoses go to on the engine cheers
Old Dec 1, 2018 | 02:40 AM
Adam-M's Avatar
Adam-M
90 degree bend on the thermostat housing which is on the front of the head and there’s an aluminium water housing behind the inlet manifold where the blue water temp sensor is
Old Dec 1, 2018 | 06:07 AM
wes's Avatar
wes
If you are running a 2wd waterpump & thermostat housing then one of the heater matrix hoses goes to the waterpump itself, on a 4x4 setup then yes to the thermostat housing.
Are you still using the standard modine between the oil filter and block? If yes then the other heater matrix hose goes to one of the water outlets on that and there is another hose that goes from the other water outlet on the modine to the outlet on the back of the head under the inlet manifold. If you don't have the modine fitted then the other heater matrix hose can go straight to the outlet on the rear of the head.
Old Dec 1, 2018 | 05:14 PM
cossynut2's Avatar
cossynut2
10 Year Member
That must be an awesome car!!!
jack-rs500
Aug 5, 2015 07:07 PM
danja
11
Dec 7, 2005 04:22 AM
Rs Gus
40
Nov 18, 2005 06:44 PM
TIFF
13
Dec 14, 2004 10:23 PM
cosworth
Oct 1, 2004 01:37 PM
