Mk1 XR4x4 fuel tank hoses
Old Nov 29, 2018 | 06:35 PM
aramsay's Avatar
aramsay
Default Mk1 XR4x4 fuel tank hoses
I'm needing a couple of hoses for the fuel tank of my '85 XR4x4....
Output hose from tank to pump.....must be max. 15mm inside diamater......doesn't seem to be a common size.
I bought one off eBay that was supposed to be correct size, but was far too loose for my liking..
Also....the large breather pipe that goes from the stub on the tank beside the filler-neck hole up to the top of the filler-neck.
Marked p/n: 83BB-9K-320AD
Any suggestions where I can get these ?
Old Nov 29, 2018 | 06:42 PM
Caddyshack's Avatar
Caddyshack
Speak to Faye at speed flow or take a look on car builder solutions?
Old Nov 29, 2018 | 09:29 PM
aramsay's Avatar
aramsay
speed flow ??
Old Nov 30, 2018 | 06:32 AM
Caddyshack's Avatar
Caddyshack
Old Nov 30, 2018 | 09:04 AM
cossynut2's Avatar
cossynut2
10 Year Member
If you have one near you, another good place is Hyphose, they stock all types and sizes of hoses.
Old Dec 16, 2018 | 10:15 AM
aramsay's Avatar
aramsay
Thanks for suggestions....
I think I'm sorted for the tank-to-pump hose, but still no joy with the tank breather hose as per the photo.
The one on the car is rock-solid, and I'm relucatant to put it back on in case it won't seal or starts breaking up....
The Ford p/n I've been told is : 1640921
Anyone got a decent used one, or know of a alternative workaround ?
Old Dec 16, 2018 | 03:36 PM
cossynut2's Avatar
cossynut2
10 Year Member
Why not try either or both of the places advised in the 2 posts above?
timotei1980
Apr 7, 2016 10:49 AM
AJC
Apr 30, 2010 10:06 PM
sam182
Nov 18, 2008 11:11 AM
Stavros
Feb 11, 2006 11:32 AM
