Anyone got pics or any details of a wrc style side exit letterbox style exhaust ...
Old Nov 23, 2018 | 09:50 PM
fatboyz's Avatar
fatboyz
Default Anyone got pics or any details of a wrc style side exit letterbox style exhaust ...
Almost at the point of starting to rebuild my cossie and always wanted to fit the full stainless as it was before but then have a y piece welded In with a butterfly valve and then also a wrc style side exit letterbox exhaust just for the extra sound when hooning 😉 I've seen a exhaust advertised for about £1100 but not seen one fitted to a saff
Old Nov 23, 2018 | 10:21 PM
smiley's Avatar
smiley
Try Marc Kinzey mk he has a resto thread in restos and rebuild section he's made a few now I think drop him a pm
https://passionford.com/forum/restor...-cosworth.html
this guy
Old Nov 24, 2018 | 10:25 AM
markk's Avatar
markk
How you going to open the butterfly?
On my Escort rally car it has twin side exit. One has a silencer and a catalyst the other has nothing. My butterfly valve is controlled by the ecu on boost pressure. Below 0.5bar everything goes quiet and through the cat. Above that through both.
Old Nov 24, 2018 | 01:31 PM
gcfcos's Avatar
gcfcos
My mate had a saph with a side exit it sounded awesome. Bit noisy on a long journey though. Be good to choose between having it open and not
Old Nov 24, 2018 | 09:58 PM
turbotrev's Avatar
turbotrev
You can get electric solenoid operated exhaust valves.
I too have thought about them
Cheers Paul
Old Nov 24, 2018 | 10:17 PM
markk's Avatar
markk
Cheers Paul
Ahh ok so just open/close.
Mine opens different amounts in line with boost.
Old Nov 25, 2018 | 08:38 AM
turbotrev's Avatar
turbotrev
Yeah the ones I’ve seen just open and close.
Very popular in the states apparently.
Cheers Paul
Old Nov 25, 2018 | 09:08 AM
Caddyshack's Avatar
Caddyshack
I think you could hook one up to a map sensor and have it open at a given boost without the ECU having to do it....or even a micro switch on the throttle position.
Old Nov 25, 2018 | 10:02 AM
fatboyz's Avatar
fatboyz
I was just gunna operate with a switch or maybe remote , but really want to see some pics of em fitted to cars
Old Nov 26, 2018 | 09:27 PM
steppy's Avatar
steppy
I am doing the same thing with a bypass valve when I get my car back from the bodyshop the valve and pipe are sat here waiting for me to fire into it
Old Nov 28, 2018 | 07:43 PM
massivewangers's Avatar
massivewangers
I don't have a letterbox one, but I just made the side exit for my rally car. Used a standard type aftermarket exhaust as a basis and, where it went round the fuel tank near the sill, chopped it and made up a section to drop out under the skirt. Had to put a bloody big silencer into it to get it to meet noise regs though. I guess a turbo car might not be so bad though.
3drRich
Nov 26, 2017 08:55 PM
M K
Feb 26, 2016 11:44 AM
Cossie Sean
22
Jan 9, 2007 08:14 AM
COSSIE CAL
14
Apr 12, 2006 02:53 PM
