any auto electricians on here
Old 19-11-2018, 11:20 AM
RetroTed
RetroTed's Avatar
Default any auto electricians on here
Just need some advice pls
I have a 91 Fiesta RST and i've lost the ignition lights on the dash. The car turns over but no lights, I've had a good look in the fuses and relays but nothing obvious. Also when the ignition is in what would be the on position there's no spark from the battery when you disconnect and reconnect the terminals which you would expect there to be, So it seems to be dead....
Is there anyway of getting power to the ignition ?
Thanks
Old 19-11-2018, 03:24 PM
Have you tried an ignition switch just so you could eliminate that.
Old 19-11-2018, 03:53 PM
RetroTed
RetroTed's Avatar
Got one coming
Old 19-11-2018, 05:41 PM
COLEYST200
COLEYST200's Avatar
Best tool you can ever get is one of these . Use one all the time when doing wiring on my card
STeve (19-11-2018)
Old 21-11-2018, 09:04 PM
RichieST
RichieST's Avatar
Power probes are great, as long as you know how to use it! Have you tested the ignition relay?
Old 28-11-2018, 10:29 PM
martysmartie
martysmartie's Avatar
I am sure it doesn't have one.
As to the problem, firstly what security system (hopefully something) do you have installed?
With a meter (or if you don't have one, a test light) check if power is present at the ignition switch and if so, move forward from there.
Martin
Mark Barber
19-06-2015 06:46 PM
ADT168
29-12-2008 06:10 PM
lardypants
08-11-2007 05:01 PM
stoddart2000
15-01-2007 05:07 PM
Quick Reply: any auto electricians on here
