resto people that actually drive there cars....
what are or has everyone used to coat hubs suspension arms beam etc , how has it held up ?????
I had stuff zinc plated and it lasted only a few days before it tarnished. Powder coat is the way to go as this lasted underneath my other car very well. I think properly applied paint as per a bodshop works but Paint seems easier to chip.
i coated the underside of my cossie with por15 anti corrosion but it was then topped off with a coat of diamond white raptor bedliner , seems good stuff but dont know how it would hold up with stone chips etc salt and general uk crap
I used this and over painted it with 2 pack for a cosmetic finish
https://www.rust.co.uk/files/pdf/3%2...MARY%20PDF.pdf
The best would be to have it hot galv sprayed and then powder coated , as the hot galv coating is the same as dipping in galv so 20 + years and then the powder coating to make it look pretty , powder coat chips but so does paint so I would always go powder coat , just have it redone every 5 years
cheers paul
cheers paul
RSmark84
156
Sep 1, 2013 07:15 PM
MJ_RST
13
Feb 2, 2009 12:17 PM
kossie
Sep 27, 2006 06:24 PM
essexrsturbo
40
Feb 3, 2005 08:10 PM
