Brake ducts
Evening all , when we last had my car out on track in October we upped the pace a bit and quickly cooked the brakes .
Fitted some ducting temporarily with cable ties to scoop air from under the car straight onto the inside of the disc ,
removed the front spotlights from the bumper and cut the bottom of the plastic arch liners off .
This gave us enough cooling but I want to find a neater ( and permanent ) solution .
Any of you with a 4x4 saff have any photos of ducting you have done successfully ?
Cheers in advance , Matt .
No-one ?
Others must have had this issue on track as it only took 15 mins of reasonably fast track use to cook the rotors .
I'm running 343 x 32 rotors with AP touring car range 6 pots .
Matt
Matt
Mad Matt
Mar 24, 2011 10:54 PM
